CobraJohn
- December 3, 2012
- Magnolia, Texas
- 2014 Explorer Sport
I wanted to provide more exterior air to my Airaid inlet by opening up the grill, but did not want to have moisture come in from an opening directly in front of the Airaid opening.
After studying the grill I opted to open my grill up in the center so there is a little offset to prevent moisture while allowing frontal air while driving to enter the grill and its symmetrical.
I took one picture with a light behind it so it shows the opening better, then another picture without the light and you can hardly tell the grill has been cut open.
The mod was fairly simple, by removing the top 10mm bolts and two push pins on the top of the grill, I pulled it slightly forward and had ample room to cut out the opening from the back side as there is a large area where the hood latch is which was plenty of room to get my Dremel in.
Next mod is to seal off the engine heat from the top of the Airaid air box as Airaid provided a seal that does not seal to the underside of the hood.
