cyberkev
- January 3, 2014
- London/Essex
- 1999 Explorer V6 SOHC 4.0
Not sure if this is the right forum to ask a few questions (I'm sure someone will point me to the right thread/forum !!!)
Did an oil/filter & air filter change when I got it and by virtue of the 5w30 semi synthetic not turning up on time discovered the timing chain hated 10w40 for the first 3 seconds on startup when left a couple of days (had some knocking about that wasnt going to get used and only used it for 50 miles). Now its got 5w30 in it's as quiet as anything again every startup. Does anyone know if the 1999 OHC's have later modified tensioners/camchains or how to tell ?
Theres not much on the dealer info / Ford ETIS system for it here in the UK being a US Export and some parts seem hard to get hold of apart from second hand (needed a drivers door latch due to a small spring broken).
I'm from London/Essex and am off somewhere in Norforlk at the weekend (tomorrow!) to collect 5 tyres for it from somewhere thats had a few floods recently.
The book says the wading depth is the bottom of the hubs, is that just because the grease is washed out of the front hubs any deeper or does water get in any rear diff breather holes or are there any low down electronics like oxygen sensor connectors that would suffer ? A quick look underneath seems to indicate most things are tucked out nicely out of the way and the air intake around the level of the top of the tyre.
On my return I was planning to do a gearbox/transfor box and diff oil change. I've got some Dextron III which supports the Ford Mercon V spec and this seems suitable for the gearbox and transfer box from what I've seen. Whats the best oil to use in the rear diff ?
Any other regular service items (besides greasing the hubs/ checking wheel bearing play) you'd recommend to do sooner rather than later if I'm planning on keeping it ?
Any advice gratefully received !
Best Regards,
Kevin
