New Product Dana 44 hub Locking nuts | Page 2 | Ford Explorer Forums
DWD is in for 2 sets also.
Pin, what pin? The Pins on mine have been gone for years.. little dab of lock tight seems to do the trick.
~Mark
Mine has been gone too -- previous owner didn't assemble it properly and the pins were done. So I ran with it. But recently, after breaking the axle shaft, I got the tire off and checked how much play there was on the disc rotor and eeep :rolleyes:. Of course I didn't use LockTite but I definitely wouldnt have ran the rig again if I knew it had that much play.
Might as well put me in for both sides. 2 sets?
~Mark
I tried that once on a Blazer years ago and even with the blue locktite it eventually worked loose. I think it would be fine on a trail rig but im weary of doing it on a street driven vehicle IMHO.
I looked into these locknuts myself some months ago, they will NOT fit in the D35 hub housing, they are physically too big.
I don't know about anyone else, but I've never once had the standard D35 bearing nuts come loose if you torque them to 225-250 ft-lbs (no Loctite either). Using the book spec. of 150 almost guarantees them coming loose however.
Put me in for both sides too.
if these fit a D35 then count me in for 2 sets as well
Put me in for a set
Cause I have had it with retighting those damm nuts
Ok here's a D-35 hub and the Stage 8 lock nuts. It doesn't look like it will work:(
Anybody from San Rafael going to Truckhaven? We could probably use about 6 sets. It's only about an 11 hour drive.
It's only 15 miles from ME..
:D
So who is still in for a group buy for their Dana 44s? Jamie, are you still interested in managing a group buy?
If they make a set that would work on a Dana 35 I'd be in.. but since it won't fit in the D-35 warn hub I won't be able to use it as it is :(
~Mark
I can't see how they would scale it down since the actual nut is the same size between the 44 and 35. The lock is what interferes. I can't see making it fit and still keeping it strong.
I'm still in.
this is odd because they told me they had confirmed they work omn the D35 ttb
I will call them today after I finish my work
Can't see how... The hub would rest on their lock ring instead of on the rotor...
sign me up for a set too D44 after all those bearings may loosen up sitting in the driveway waiting for a new motor, lol
