New rotors?
rollinstone
1997 Ford Explorer XLT
As I'm slowing to a stop the Ex seems to rock as it slows...don't know how to best describe it...oh, as if the rotors are warped! Got 125K+, never changed the rotors. Time to do so? Inspected pads and they've got plenty remaining.
What set do I need specifically? '97, ABS, AWD.
Tks. r.s.
JohnnyO
Moderator Emeritus
Pittsburgh, PA
'08 Sport Trac
Yeah, I'd say it's time. With 125k, it must be flat where you live. I've bought the heavy duty NAPA rotors for a couple of my vehicles. I like them real well and they don't cost a ton.
saewoody
CT
1997 XLT (RIP)
2003 XLT
Definitely time! I've been happy with both Wagner (from Acme Auto) and Prostop (PepBoys).
I know you said you had a lot of life left in the pads, but if you have the extra cash to spare I would say to change the pads too. If the rotors are warped, the pads are probably not wearing that well right now. Also, why throw on on pads with brand new rotors?
chrisis
Murray, kentucky
2000 ford explorer xls
if you have extra money to spend i will get 4 new rotors and pads.i'm using powerslot with hawk brake pads for 2 years now and i never had any problem since, even when i was towing for 17 hours they never let me down.
if you don't want to spend too much money just turn the 2 front rotors, get new brake pads for them and you should be fine.
Vinniety
Westchester county, NY
2000 sport
Like everyone stated go for pads as well. New pads on new rotors will last you another 125k miles. HAHA
Where are people buying hawk pads from? My local autopart store doesnt carry them.
JohnnyO
Moderator Emeritus
Pittsburgh, PA
'08 Sport Trac
hotrod_ron
Tulsa, Oklahoma
96 Explorer Sport
Rotors and pads
I am running cross drilled and slotted rotors i got off of ebay...there R1 concepts....also running Hawk brake pads, got them at PepBoys....the combination works great....the Explorer has never stopped so good.
Also running Edelbrock Performer IAS shockes, Energy Suspension poly bushings all the way around. 96 2 door 2wd Sport
Vinniety
2000 sport
hotrod - which HAWK pads are you using. Tire rack has a few diefferent ones. Mine would be for daily driving.
thanks
hotrod_ron
Tulsa, Oklahoma
96 Explorer Sport
brake pads
Hey Vinniety, I am running the Hawk HPS (High Performance Street) pads. They are kinda pricey, but in my opinion, well worth the money. My X stops on a dime and gives you change. I am not sure how they will work with stock rotors...im sure way better that OE type.
Anyone know where I can get a set of stainless brake lines for the X? Just want them to replace the stock rubber ones at the caliper....thanks
Nocturnall
Tempe, AZ
1997 Sport
I think explorerexpress has stainless lines. I'm useing r1concepts rotors and Raybestos pro pads and my x stops crazy fast. I installed them then drove cross country fully loaded and it stoped about as well as it did with stock pads. granted it wasn't like towing something but I probably had 2000lbs worth of stuff in the truck. LOT'S of tools and cloths and stuff hanging off the x everywhere the whole drive.
S 98 explorer HELP!!! NEW alternator put in, mechanic says stuck in "anti theft" stealth mode **UPDATE**WAS THE STARTER -NOW BALL BEARINGS BRAKES/ROTORS Stock 1995 - 2001 Explorers 47
L pads rotors Stock 1995 - 2001 Explorers 10
E Rear rotors recommendation Stock 1995 - 2001 Explorers 5
B All new rotors/pads and right front is rubbing?!?! Stock 1995 - 2001 Explorers 15
T Need rear rotors for 2003 Ford Explorer XLT Sport 4.0 Stock 1995 - 2001 Explorers 1
D Warped Rotors? Or something worse? Stock 1995 - 2001 Explorers 2
A Canadian Market brake rotors different than US market for our trucks? Stock 1995 - 2001 Explorers 8
K 2004 Ford Explorer Sport trac front brake rotors minimum thickness Stock 1995 - 2001 Explorers 3
S Which rotors and pads for 1997 V8 AWD? Stock 1995 - 2001 Explorers 3
D Question on brakes and rotors Stock 1995 - 2001 Explorers 4
K Great and easy way to remove stuck rotors Stock 1995 - 2001 Explorers 13
C Front Rotors Rusted and Seized - 2000 Explorer Stock 1995 - 2001 Explorers 14
T Source for Brembo rotors Stock 1995 - 2001 Explorers 4
S Correct Rotors/pads for 2000 Sport? Stock 1995 - 2001 Explorers 11
shadowless127 What are the best rotors and pads to use? Stock 1995 - 2001 Explorers 7
T Opinions on Summit Racing Rotors Stock 1995 - 2001 Explorers 2
B rear brake rotors seize to Ford 8.8 axle Stock 1995 - 2001 Explorers 19
8 New Rotors/Pads - Now NO pedal Stock 1995 - 2001 Explorers 24
E pads & Rotors Stock 1995 - 2001 Explorers 2
R Informal Survey: Best brand for rotors for 2001-2005 Explorer? Stock 1995 - 2001 Explorers 0
M Front rotors TURNED BLUE!? Stock 1995 - 2001 Explorers 30
mounty71 Brake Rotors--Bosch Quietcast? Stock 1995 - 2001 Explorers 11
Tbars4 95-01 Rear Brake Rotors Question Stock 1995 - 2001 Explorers 4
B Brake Heat, Rotors, Pad Types Stock 1995 - 2001 Explorers 7
B Brake Rotors, Front One-Piece, 2000 Explorer Stock 1995 - 2001 Explorers 11
A New Brake Pads/Rotors Shakes Stock 1995 - 2001 Explorers 4
T anyone replacing rotors - I want your tone ring Stock 1995 - 2001 Explorers 8
R Front rotors or front hub bearings??? Stock 1995 - 2001 Explorers 0
shadowless127 Grinding when braking - new pads/rotors Stock 1995 - 2001 Explorers 6
H Powerslot rotors & hawk pads - Q. Stock 1995 - 2001 Explorers 3
G '96 xlt 4dr 2WD V/8 brake rotors Stock 1995 - 2001 Explorers 3
toypaseo $102.39 Brembo Sport Slotted Rotors or $154.97 Centric Powerslots? Stock 1995 - 2001 Explorers 0
0 Rear Rotors Stuck 99 EB AWD Stock 1995 - 2001 Explorers 14
T Cross drilled/slotted rotors worth the money? Stock 1995 - 2001 Explorers 16
B 1997 Mounty Cant get rear rotors off Stock 1995 - 2001 Explorers 15
D Squeaky Brake Pad After New Pads and Rotors Stock 1995 - 2001 Explorers 6
toypaseo Raybestos Professional Grade rotors and pads good? Stock 1995 - 2001 Explorers 7
D Replacing Front Rotors. Stock 1995 - 2001 Explorers 3
2 Who has powerslot rotors? Stock 1995 - 2001 Explorers 3
R Front rotors worn out unevenly Stock 1995 - 2001 Explorers 16
F new pads on worn rotors Stock 1995 - 2001 Explorers 9
C Brembo or Powerslot rotors? Stock 1995 - 2001 Explorers 14
R What type and brand of pads and rotors work best Stock 1995 - 2001 Explorers 7
J Can over tightening lugs cause warped rotors? Stock 1995 - 2001 Explorers 4
J Time for new front rotors....need advice, please Stock 1995 - 2001 Explorers 2
Afboy143 Problem with new rotors Stock 1995 - 2001 Explorers 3
M Front brake rattle after putting in new pads and rotors Stock 1995 - 2001 Explorers 9
M Replacing rotors/pads on all 4 wheels/ which ones to get? Stock 1995 - 2001 Explorers 4
I do i need new rotors or not? Stock 1995 - 2001 Explorers 6
Y Should I replace front rotors? Stock 1995 - 2001 Explorers 17
Similar threads
