New steering rack
toms2012
Kentucky
2012 Explorer
I got the steering rack replaced this month due to the power assist fault recall. I am not sure if the new handling characteristics are same as before. The vehicle does seem different now. When going down the interstate I am constantly correcting the steering. If I make a slight correction left or right than the Explorer takes off in that direction. The vehicle does not want to return to a neutral straight path. The steering does not pull left or right but will continue to drift in whatever direction I corrected. I have new Goodyear tires with less the 200 miles on them, but vehicle had same character two days before with original equipment tires. Anyone else have the rack replaced and had similarities?
FordService
Official Ford Rep
Dearborn, MI
I got the steering rack replaced this month due to the power assist fault recall. I am not sure if the new handling characteristics are same as before. The vehicle does seem different now. When going down the interstate I am constantly correcting the steering. If I make a slight correction left or right than the Explorer takes off in that direction...
Since you're concerned, toms2012, it wouldn't hurt to have your dealership check this out to ensure everything is within spec. How many miles are on your Explorer?
Crystal
imbett
bayfield ontario CANADA
12 exlt cinnamon metallic
re sterring
I think alinement is off some .I have a 2012 and just came in from a drive and this i checked It is as straight as an arrow with hands of wheel .Take it back and have aline checked
toms2012
Kentucky
2012 Explorer
The alignment was set when the steering rack was replaced. The Explorer has just over 45xxx on it. The tires were replaced 3 days after having the rack replaced and exhibited the same issue with steering. I don't have time to get it in this week but i do think it deserves another look by the techs.
182RG
Winchester, VA
'11 XLT / '13 Touareg TDI
Take it to an independent shop that specializes in alignment and pay to have it done right.
rfs2005
2014 Explorer Base
[MENTION=190968]toms2012[/MENTION]. Your issue with the tracking is one of the symptoms I am currently experiencing on my brand new Ex. Mine does pull to the right, though. It does also not want to return to center when making minor steering corrections. My Ex is in the shop now. They've aligned the front wheels to death, and it's not working. Hopefully it is just a defective steering rack.
rfs2005
2014 Explorer Base
FordService
Official Ford Rep
Dearborn, MI
Send me your info in a PM, toms2012; I want to get your regional customer service manager involved. I'll need your full name, best daytime phone number, VIN, mileage, and servicing dealership.
Thanks for keeping us updated on your Explorer, rfs2005. I checked out your case and see that your CSM left a message for you this morning. They'll be following up with you again on Wednesday. Be sure to let me know if you need any additional assistance. :thumbsup:
Crystal
toms2012
Kentucky
2012 Explorer
I thought a follow up was in order. After driving a Focus for the month it took to fix my Explorer my vehicle is driving great. The new steering rack has exceeded my hopes after learning to 'feel' the Explorer again. Coupled with new tires the ride and handling is better than new. The new steering rack has as a bonus eliminated the majority of torque steer. I can now stomp the gas pedal without the fear of veering left.
Thanks for the offer of help Crystal. Glad we didnt have to go further with this issue.
gomli
Ottawa, Ontario
2012 Ford Explorer XLT
Hopefully I won't have this issue, won't have my Explorer back for another 3-5 weeks they said. Parts are on back order.
Now I have to drive in a little Focus... can't tow my boat with the Focus... :mad:
jrmexplorer
2011 Limited
I got the recall done several weeks ago. I did NOT have a new steering rack installed because I didn't have any problems previously. They only updated the software on mine.
Just like you, I noticed that after the software update was done that torque steer is basically gone.
FordServiceCA
Official Ford Rep
Oakville, Ontario
Ford Explorer
I'd like to look into this further, gomli. Please send me a private message with your full name, VIN, updated odometer reading, best daytime contact number, servicing dealership, and some information about the parts you're waiting on. I'll be on the lookout for your response.
Brittany
C Strut or steering rack? Stock 2011 - 2019 Ford Explorer Discussion 2
S New Steering Rack - 2014 Sport Stock 2011 - 2019 Ford Explorer Discussion 1
X Steering Rack bushing Stock 2011 - 2019 Ford Explorer Discussion 2
R First the steering rack failure, and now throttle failure ??? Stock 2011 - 2019 Ford Explorer Discussion 6
A Ford Explorer 2011-2013 Power Steering Failure Stock 2011 - 2019 Ford Explorer Discussion 1
K Steering wheel buttons Stock 2011 - 2019 Ford Explorer Discussion 0
K Steering right tight, left loose Stock 2011 - 2019 Ford Explorer Discussion 3
B Popping/grinding noise coming from under the front end when steering left or right Stock 2011 - 2019 Ford Explorer Discussion 4
R Steering assist fault on a new sport Stock 2011 - 2019 Ford Explorer Discussion 6
D Sync upgrade and steering program Stock 2011 - 2019 Ford Explorer Discussion 1
M Hello :) Ticking / Clicking noise heard when rotating steering wheel Stock 2011 - 2019 Ford Explorer Discussion 5
S Steering Wheel Power Tilt/Telescoping Function Not Working Stock 2011 - 2019 Ford Explorer Discussion 2
L Loose handling / steering? Stock 2011 - 2019 Ford Explorer Discussion 3
W Steering fluid Reservoir? Stock 2011 - 2019 Ford Explorer Discussion 3
M Random new noise in steering column Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport steering clunk help please Stock 2011 - 2019 Ford Explorer Discussion 10
T Cleaning steering wheel Stock 2011 - 2019 Ford Explorer Discussion 6
S 2019 Sport - squeaking/moaning steering wheel? Stock 2011 - 2019 Ford Explorer Discussion 7
G Power Steering recall 15N01 Stock 2011 - 2019 Ford Explorer Discussion 7
T Two issues--HVAC and Steering Stock 2011 - 2019 Ford Explorer Discussion 10
F 2016 Sport Steering Issues Stock 2011 - 2019 Ford Explorer Discussion 10
N Steering Wheel Airbag Stock 2011 - 2019 Ford Explorer Discussion 1
A 2016 explorer XLT squeaky noise when turning the steering to the left only Stock 2011 - 2019 Ford Explorer Discussion 1
M Steering sticks in 12 o'clock position Stock 2011 - 2019 Ford Explorer Discussion 5
B loose steering? Stock 2011 - 2019 Ford Explorer Discussion 3
S Knocking noise when steering slow speed Stock 2011 - 2019 Ford Explorer Discussion 14
C Power Steering Issues? Stock 2011 - 2019 Ford Explorer Discussion 18
L ‘13 Ford Explorer steering problems Stock 2011 - 2019 Ford Explorer Discussion 3
X Strange creaking noise - almost behind steering column... Stock 2011 - 2019 Ford Explorer Discussion 1
C 202a U.S. vs Canada - Specifically, Heated Steering Wheel & Foot Controlled Liftgate Stock 2011 - 2019 Ford Explorer Discussion 13
V Steering Wheel Memory Intermittent Stock 2011 - 2019 Ford Explorer Discussion 2
M Power steering settings (ForScan) for 2018 Explorer (non-Sport) Stock 2011 - 2019 Ford Explorer Discussion 1
F no power steering/battery warning when first started. intermittent Stock 2011 - 2019 Ford Explorer Discussion 21
E Power Steering Noise Stock 2011 - 2019 Ford Explorer Discussion 2
Daheim111 Steering wheel noise...only from the upper part of the column ? Stock 2011 - 2019 Ford Explorer Discussion 6
E Squeek when turning steering wheel Stock 2011 - 2019 Ford Explorer Discussion 3
D 2014 ford explorer Steering problems Stock 2011 - 2019 Ford Explorer Discussion 2
Jon M Small 2017 Recall Steering Gear Heat Shield Stock 2011 - 2019 Ford Explorer Discussion 0
F Power Steering Assist Failure Stock 2011 - 2019 Ford Explorer Discussion 4
P A/C comes on when turning steering wheel Stock 2011 - 2019 Ford Explorer Discussion 4
Z Steering wheel squeal Stock 2011 - 2019 Ford Explorer Discussion 1
S Power Steering Recall - Ford Refuses to service Stock 2011 - 2019 Ford Explorer Discussion 4
R Cabin hum and Steering wheel/column vibration Stock 2011 - 2019 Ford Explorer Discussion 1
P 2017 Platnium WITHOUT a wood trimmed steering wheel Stock 2011 - 2019 Ford Explorer Discussion 10
S Heated Steering wheel with "cold vents"? Stock 2011 - 2019 Ford Explorer Discussion 14
I Power Adjustable Steering Column and Pedals stopped working Stock 2011 - 2019 Ford Explorer Discussion 4
S Steering wheel lighting Stock 2011 - 2019 Ford Explorer Discussion 6
F Electronic Steering Control Stock 2011 - 2019 Ford Explorer Discussion 4
S Wobble in steering at low speeds Stock 2011 - 2019 Ford Explorer Discussion 4
J Steering wheel turns to right and back to left when accelerating feom stop Stock 2011 - 2019 Ford Explorer Discussion 16
Similar threads
