New to me 2010 Mountaineer AWD V8 | Ford Explorer - Ford Ranger Forums - Serious Explorations
AZExploder
Phoenix, AZ
2010 Mountaineer Premier
Hi
Started here as with a 1991 Explorer 4.0L 4x4 a few years ago.
Now - i have had a 2010 Mercury Mountaineer Premier AWD 4.6L for an entire 3 days...
Just purchased today:
  1. Gibson 319692 exhaust
  2. TRAXX Front and back lift
  3. Superchips 1842
  4. K&N filter
  5. Double Plat Autolite
  6. Cooper Discoverer AT-3 265/60-R18
Going to have quite a party when the parts all get here and I can start plugging things in.
AZExploder
Phoenix, AZ
weeeeell.. looks like the Superchip is not going to work with the V8.. bummer.
4 sail now.. P-(
Explorer75
FL
4 sail now.. P-(
When you get rid of it contact More Power Tuning they should be able to tune that truck. You will need an SCT flasher and a custom tune form them. I recommend it, they transformed my 4.0 truck, some people don´t believe in tuners but I do, they enhance drive ability and make the truck more enjoyable.
AZExploder
Phoenix, AZ
Gibson is in, Hypertech tune is installed
Dang, you would think the fellas at Gibson would listen a bit to some of the boards.. The pipe into the rear of the muffler STILL needs to be trimmed about half an inch and the old bolts to the cats WILL NOT WORK.. You need to get some grade 8 or SS to supplement...
PITA #1 was getting the hangers free. Lots of lube...
Hint - CUT the old exhaust behind the muffler where it starts up.. just do it
PITA #2 was the back pipe fitting needing trim.
Hint - go ahead - test it.. but DO NOT FORCE it.. then go ahead and cut it.
PITA #3 lining up the last pipe around the spare tire guide.
Hint - Use blocks of wood to hold it pressed into place and then clamp. I will be having it welded once my neighborhood lift is clear of a 4.0 to 5.0 Ranger swap.
It sounds good. Not my 5.4l Expedition with Headers/High Flo Cats/ Gibson CBack.. but it is nice. I don't like it loud, but this rumbles like a V8 should now.
If you do not want to hear it - just leave the exhaust alone. Really.
matsavol
Dallas, TX
'06 4.6L EB
You could have referenced the Gibson exhaust thread:
http://www.explorerforum.com/forums/showthread.php?t=359385
AZExploder
Phoenix, AZ
Transmission fluid drain and filter replacement - mag was fuzzy as expected
Diff fluids drained - back was black, front was clean
Transfer case fluid swapped - clean
Now just waiting to install the TRAXDA and an alignment.
AZExploder
Phoenix, AZ
part 4
Truxxx front installed. Side one - 2 hours, Side two, 30 minutes.
Rear go on Tomorrow.
For those doing the transmission pan drop on the 6r80, mine was just 5qt+, not 7qt+. Filling was not fun and the extra qt i tried to stuff in there shot out the hole when I removed the fill tube. messy, messy... I wish I had done the lift first.
yoster
Clovis, CA
'06 Eddie Bauer v8 4x4
4 sail now.. P-(
Fear not! SCT has you covered:
http://www.sctflash.com/products.php?PID=74&VID=466
Or their other tuners (same tune - different device): http://www.sctflash.com/showproducts.php
I use that device on both my Focus ST and 2006 Explorer 4.6L
Of course though, do note, tuners don't make NEAR the power on vehicles with no forced induction vs those that do. For instance on the explorer, it adds maybe 10-15hp, but you don't really notice unless you're on the dang thing.
On the Focus ST (2.0L turbo) - it's like a COMPLETELY different car when I load up the tune.
Also, if you're so inclined, you can load up custom tunes on the device. I know a few reputable tuners if you're interested - let me know. I do this exact thing on my Focus. I have SCT's pre-loaded tune maps, but I also have a custom tuner that has more aggressive files he's created for my vehicle. They can do the same for the explorer.
