Hello, This will be my first real experience with towing and I have a couple questions. My wife and I are thinking of buying a small travel trailer. It’s a 19ft model that weighs around 3600 - 3800 lbs. loaded up, its 3400 dry. I have a 2003 explorer 4.0L. It has a class 3 hitch and trailer braking system installed. After seeing the upgraded hitch I figured it had the towing package and figured we were good to go. Well after doing more research and checking the door code I’m pretty sure I have the 3.55 gears. I verified it has a trans cooler and the hitch is rated to 8000 Lbs. We live in FL so there will be little to no hills involved. I also plan to get the load balancing hitch and anti-sway setup. Will this vehicle work to tow that trailer?
Thanks in advance
Thanks in advance
