New v3.0 Build Available
UofMEngineer
Michigan
17' Escape Titanium
FYI, the latest update is available on the owner portal. Should also be OTA as well.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
MM07
MA
2018 Explorer Limited
Not in my portal online. Will check OTA.
UofMEngineer
Michigan
17' Escape Titanium
Should be available via both the owner portal as well as OTA.
MM07
MA
Just tried in my EXP. Let it check for 10 minutes. Gave up. I'll try tomorrow.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Downloaded mine to the computer then USB Drive. Since the update may take up to 30 minutes according to the instructions, I'll try that part tomorrow when I Have a short trip to make since the vehicle has to be running.
peterk9
Staff member
Moderator
Callsign
VE3
My currently installed version is already V3.0. It was installed about a year ago. I believe the build is 19083. Is this latest update in addition to what I have?
UofMEngineer
Michigan
17' Escape Titanium
This latest release is 19205. The one you have now should be 18093.
peterk9
Staff member
Moderator
Callsign
VE3
Thank you. Current build likely is 18093. Right numbers, wrong order.:)
MM07
MA
Still nothing on my Portal.
peterk9
Staff member
Moderator
Callsign
VE3
RHall
Blue Bell, PA
19 Explorer Sport 4WD
Am running 18093 currently in a 2019 Sport, tried OTA with no luck, and the site is unresponsive right now - just spins forever on the "Update Your Sync Software" page here: Download The Latest Ford SYNC® 3 Update | Official Ford Owner Site
It looks like they are right in the middle of or just within the past few days did a migration to using IBM's third party SSO oAuth for handling logins (you might notice the different look for the login), which could be adding to the problems. They might also be doing a staggered release, but right now its just not functioning properly. Sigh...
tlveik
2018 Explorer XLT
My current build is 17276. I opened up the autoinstall.lst file and see these two lines with version numbers.
SYNC3 Consumer Assembly Upgrade - Release 3.0.21 - Only for NonNav/NonEU assemblies.
[SYNCGen3.0_3.0.19205_PRODUCT]
Did I see somewhere that this adds Waze? Or improves Waze? I've never used Waze before. Does that use the same internet connection that Ford Pass uses?
Tom
MM07
MA
Just tried OTA...just spinning and spinning.
MM07
MA
Tom
Waze might of been a part of 18093, which has been out for a bit.
peterk9
Staff member
Moderator
Callsign
VE3
Ran the update in the Explorer tonight and it took no more then 5 minutes. Build is now 19205. Also reported successful update completion back to my Sync account site.
peterk9
Staff member
Moderator
Callsign
VE3
I'm not aware of anyone who has been able to run the update over the air.
ilguy
Chicago
2017 Explorer Platinum
I ran my update successfully via USB. Any idea what it fixes?
KarmanExplorer
DFW
2019 Explorer Limited
Just updated my 17 Escape and 19 Explorer using USB. Update took a minute or so to actually start the update and then maybe 5 minutes to finish. Did turn off the auto update feature in the car to use the USB. Not sure if that is required.
Ferretkingdom
LEHIGH ACRES
My '18 explorer has build 17276. It tells me it's up to date when I check for updates over wifi. Will it only do the user updates via USB, since I actually want actually up to date even before this newest release
Similar threads
