Goober
- May 23, 2000
- Lexington, SC
- '91XLT4x4
M15000 SELF-RECOVERY WINCH
This newest Warn winch boasts new high strength carrier plates to handle the gear train stresses of a 15,000 lb load. The gear ratio is 315:1, with 90 feet of 7/16" wire rope equipped with a large latched hook. The control pack is designed for generous clearance and ease of access.
Dead Link Removed
M15000 SPECS/PART NUMBERS:
Part Number: PN 47801
Rated line pull: 15000 lbs. (6800 kgs.) single-line
Motor: 4.6 hp, Series Wound
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: 3-Stage Planetary
Gear ratio: 315:1
Lubrication: Molylube #1 or Aeroshell #17
Clutch (freespooling): Rotating Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 3.5"/8.2" (9cm/21cm)
Weight: 136 lbs. (62kgs.)
Wire rope: 90', 7/16" diameter (27m, 11mm diam.)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72" (1.83m)
12V DC PERFORMANCE SPECS:
Pull by layer: layer/Lbs(Kgs.)
1/15000(6804)
2/13890(6300)
3/11520(5225)
4/9840(4463)
and remember:
Do not use winches to move people.Dead Link Removed
Dead Link Removed
Gear ratio: 315:1
Fairlead: Roller
1/15000(6804)
2/13890(6300)
3/11520(5225)
4/9840(4463)
and remember:
