Bbirge89
- November 13, 2013
- 2005 explorer sport trac
So I've been losing fluid from my radiator at a very high rate and from every angle I could see, the water pump was the most probable source. I replaced the water pump and began to fill my radiator and once the fluid hit thermostat level, I see the leak just as bad as ever. I think the leak is coming from somewhere on the back of the thermostat housing. Once I got the upper thermostat housing out, I could see there would be a problem with the very back 8mm bolt to dismantle the lower portion. I had no clearance for socket or wrench or anything for me to loosen it. I took the cables that ran to my generator off to make more room and took a few hoses off, including the vacuum hose and upper hose to the thermostat. While I still do not know for sure where the leak is coming from, I'd really appreciate any help on how to real the 8mm bolt without possibly a smaller version of my 8mm swivel socket. Any info or help will be very much appreciated. 2005 ford explorer sport trac 4.0L v6 SOHC
