eric4welches
- July 6, 2009
- OR
- '92 XLT
On my 1992 XLT (4WD), I replaced the front rotors and wheel bearings. It seems that I just can't seem to get the right "tightness" or torque. I follow the forum threads to set the wheel bearings, then back it out, then tighten to 16" lbs (finger tight). I then check the play of the wheel/bearing assembly by grabbing the tire at 12 and 6 to see if it's loose by rocking it top to bottom. I also spin to tire to get a feel of the "drag". I just can't seem to get the tightness correct. If there is too much "wobble", I tighten the wheel nut so the retaining ping fits into the next "notch" but seems to tighten the wheel too much based on the drag when I spin the tire. With the retaining pin in it's previous slot, it seems like there is play in wobble when rocking the tire.
I've looked looked behind the tire for other reasons for the looseness but can't detect any other reason for the wobble when I think I have the right torque or tightness.
Suggestion on this would be GREAT.
