HeyNiceSporty
- December 13, 2023
- Clearwater, Florida
- 2010 Sport Trac Limited
Along with the Ironman grill and Smoke Headlights, I have added these Wolfx fog lights. I think this really cleans up the looks on this front end.
The fog lights have a halo built in and I have yet to wire these up. Unless someone has a better idea, I was thinking of tapping into the front side marker light. I think the halo would look good running at the same time as these, but I am open to other ideas.
By the way, if you are looking to remove the stock fog lamps, they mount to the fascia on three posts. These posts have three tabs each and make it super-easy to simply jam the fog light into place at the factory, once and done. They make it a little struggle to get them out. The tabs need to be pressed in to be able to push the post back out. The simple solution I figured out was to use a medium cable tie. Place it over the tabs, pull it snug and you can press the post forward. I was able to do this by finger pressure on 5 of the 6 posts. One needed to be tapped on a bit to move it as it was snug. I was able to reuse the cable tie on each post.
The fog lamps are sold on eBay by several vendors. Overall they seem good quality, but I did add heat shrink tubing to the connectors. They seemed too exposed, especially for a damp Florida climate.
