It's getting there. We rolled it out of the carport today on all 4 of it own wheels so we could roll in a small tractor that needed a new clutch.
Did you know that tractors don't have frames? When you split the engine and tranny (lots of bolts) the two haves just roll away on the front and rear axle.
Anyway, need some crush washers for the front brakes, run some new hard lines across the rear axles, set the rear pinion angle and burn in the spring perches, attach the headers and exhaust, seal and fill the 9 inch pig, run the rear hard lines across the axle, bleed the brakes, and add shock mounts to the rear axle. THe only hold up may be lengthening the rear drive shaft, and the gears of course.
