Nitrous Bottle Openers
Stomper
Syracuse, NY
'97 Sport 4.0L SOHC
Nitrous Remote Bottle Openers
Anyone with nitrous is going to eventually want to get a bottle opener.....trust me. The main mfg's that everyone is familiar with are Nitrous Express, NOS, and ZEX:
The NX and ZEX kits are valve openers. That means that they use the nitrous bottle valve to open the bottle mechanically just like you'd do with your hand. The NOS is a solenoid opener and screws onto the bottle just like a stainless delivery line. The beauty of the NOS model is that a solenoid opens almost instantaneously when power is applied and it's doubles as a safety shutoff, too. The NX and ZEX kits are still very nice, but are actually opening the bottle valve and require approx 2 seconds to open.
I just bought the NOS solenoid type from Alec. With his help, I installed during my lunch-hour today. There are 3 wires Red, Black, and White. Red is 12V open, Black is 12V close, and White is ground. You can NOT see the valve opening thru the in and out ports, because the solenoid resides deeper inside the opener.
Because, it locks open and closed, all that is required (if you buy one used) is a momentary (self centering) rocker switch. Switches usually work in the opposite direction they are wired, because of the way contacts are closed:
From
Opener................Switch............Vehicle
Black Wire --- OPEN BOTTLE --- to +12V
White Wire ------- OFF------- to Ground
Red Wire ---- CLOSE BOTTLE --- to +12V
A few extra fittings were required to bolt up to my ZEX kit, so make sure you know what size AN fittings your system has. Always remember to check all nitrous fittings for leaks after making any changes to your system. If you see any icing around a fitting, then shut the bottle off immediately and investigate.
I'll get some pictures of the install probably this weekend. Toooo bizzeeeee! Happy spraying!:cool:
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
you will only find one problem with use of a remote bottle opener- you use nitrous too often. :D its just too tempting to have it there anytime you want. refill about 3 bottles in one week, you'll rethink it. trust me, you'll be spraying up offramps to get on interstate quicker etc.
Stomper
Syracuse, NY
'97 Sport 4.0L SOHC
DAMMMMEEEEEEEET! Never thought of that, James T! :banghead: HAHA!!
I'm probably going to need a part time job to support my N2O habit now. To hell with crazy theivin' crackheads.....watch out for nitrous junkies.....gonna be looking for loose change in the couch and under the seats to fill up my bottle! :p
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Glad you're happy!
Troll
I have had the NO2 opener for about 2 years now and it works pretty well for me.
3 Nitrous Need for Speed! 0
Awon2zip Nitrous 1994 Explorer Need for Speed! 278
1 Nitrous for the first time.... Need for Speed! 45
S Will a stock 5.0 handle a 200+hp shot of Nitrous? Need for Speed! 29
R Pics of my Lincoln LS nitrous setup... Need for Speed! 25
R 2005 Lincoln LS w/ 100 shot nitrous new best ET's 11/18/06 Need for Speed! 13
C nitrous questions Need for Speed! 10
S Nitrous.....Who has it? Need for Speed! 31
K Official 4.0 SOHC Nitrous Thread! Need for Speed! 4
boominXplorer My nitrous purge kit is on! Need for Speed! 5
S Nitrous injector..... Need for Speed! 15
V Question on spark plugs for nitrous system Need for Speed! 8
V Wanting to install nitrous, what all will I need? Need for Speed! 8
E nitrous cam, and in-car cam swap info thread Need for Speed! 15
E more intelligent nitrous questions Need for Speed! 0
E nitrous with stock fuel... 5.0 x and 3.0 dohc escape Need for Speed! 18
boominXplorer Boomin Gets NITROUS!!! Need for Speed! 39
C Nitrous( beat the dead horse ) Need for Speed! 6
S ZEX dry Nitrous, has got to be a joke Need for Speed! 19
S Nitrous mods Need for Speed! 2
S What do you pay for nitrous?? Need for Speed! 7
S Nitrous tips / general info Need for Speed! 20
A nitrous Need for Speed! 12
james t i want my nitrous back! Need for Speed! 22
Alec The nitrous oxide is no more.... Need for Speed! 7
4 Nitrous Express Need for Speed! 6
U Nitrous from the `Stang? Need for Speed! 8
Alec Note to nitrous users Need for Speed! 3
E Nitrous Shots Need for Speed! 4
Alec Project Splat: Nitrous Oxide Need for Speed! 28
Similar threads
