nitrous cam, and in-car cam swap info thread
Status
Not open for further replies.
expo5.0
Red Wing, MN
1996 xlt
p
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
I have a 35-306-8 sitting in a closet in a bedroom new in box. If you want it, its yours for $100+shipping. Dual pattern boost/nitrous cam, 2000-6000 rpm band.
BeauJ
Moderator Emeritus
James, I'm still interested. I'm gonna call comp cams tomarrow and see what stall would I need and if I have to notch the pistons.
Glad to see you've stepped into the world of engines Expo. To start, if you'll really going to nitrous, go with a dual pattern cam. But the thing is, the bigger you go lift wise, the higher stall you will have to get to take advatage of the power. Also, if it's too big you'll have vacuum issues with the brakes, but this can be fixed by a aftermarket vacuum booster. Comp cams have a very good reputation. If I dont get one, it will be a custom then. You can leave the motor into swap the cam, but you might have some clearance issues since youre lowered. Yes, the springs will have to be upgraded. It says you have 1.6 rockers, good start. If you're gonna be running nitrous a good bit, I'd upgrade the valves so I wouldn't burn them up. For mild cams you don't need a reburn, but with a larger one Apten can handle it. With all the upgrades I'm going for, I'm gonna be doing ALOT of reburns. Don't really know where to save money unless you look on eBay. But don't skimp around on the top end of the engine. It's gonna take some money to make it run good and you don't want to worry about being an hour from home and a spring decides it's got other plans. As for books, Summit racing has a book and movie that an old friend bought and he said it was helpful. But im not really sure, as I wasn't a driver then
expo5.0
Red Wing, MN
1996 xlt
have a completely new plan
expo5.0
Red Wing, MN
1996 xlt
also- choppin you came across as a little condescending there. maybe its the internet, but i wouldn't answer your questions like that if you asked a question about anything other than engine stuff
BeauJ
Moderator Emeritus
Expo, didnt mean to sound condescending at ALL. I'm not that type of person. Honestly, I was just trying to help. I certainly wouldn't go in depth with some newbie who I didn't think was serious about it all.
If you're going with 24 lb injectors, I'd do the 255 swap. I read an article in MM & FF about the TRUE measurements on the the pumps. You have to have the perfect voltage/pressure to pull it off the highest reading. If you wanna pull the full 100 shot, I might go with 36 lb. injects.
expo5.0
Red Wing, MN
1996 xlt
hey, no problem at all
we're all set
expo5.0
Red Wing, MN
1996 xlt
james- that means that one will work nicely with the stock tq converter correct?
hell, i'll just take it either way. if you bought it for your truck, you know what your doing. someone tell me its wrong, or i'm gonna buy it. I didn't get the greatest impression from the guy at comp who told me to get the other one instead.
i'm officially calling dibs
also, i need another set of 1.6s now. my cam is going in my little cousins truck fo sho. you have em james? what about springs? do i need to do em?
one more question- do i use the same in tank fuel pump as the 87-93 stands and 94-95 cobras... i bet i do, but want to make srue...
expo5.0
Red Wing, MN
1996 xlt
ya'll are driving me nuts. i need to know the answers, lol. i'm pretty dang excited about this crap i guess.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
1- Itll work okay with the stock converter, but you will want some stall eventually. Stall is what will make the rig fly off the line at the track. The cam i have is pretty lumpy so it would be a good idea to get a converter.
2- I dont have anything to go with the cam... i sold everything else. You will need new springs (986-16). The cam is recommended to run with 1.6 rockers.
3- Your X has the same style intank pump as the mustangs. You can run any of the various aftermarket intank pumps. Go big.... no sense in dropping the tank unless you throw a 255 in it IMHO.
Something to think about- you will need to have someone check piston to valve clearance on this cam. I know in a stang it'll work..... but i honestly dont know in an explorer. Worse case scenario is you will need to clearance the pistons. Its not a big a deal as it sounds.... there are kits on the market that let you do this with the motor assembled. That other cam the guy at Comp recommended you is really big and would be REALLY close on the valves. It would also suck donkey balls with stock heads and no stall. The one i have is a bit more "mid-rangy" and i think would work better in an explorer.
expo5.0
Red Wing, MN
1996 xlt
james- i'll do it. and try to figure out the answer to the piston to valve clearance. let me know where to send money. I will be running stock torque probably indefinitely. don't care enough about getting off the line to necessarily make it worth the cost, but either way if it will run for now without it i'm happy. i take that back, expect to see a new converter about 6 weeks after i install all this.
i decided to do the nitrous last week and have the kit, new pump (255 walbro), and the cam (from you) already on their way to me so who am i to say i won't do the converter too.
i have one more important question though- can i use stock valve covers properly with the 1.6 RRs? i know mine are stock as is, but i'm not sure what was done to them to make it fit. i keep getting conflicting reports on this one. like i said i'll actually be doing cam swaps in 2 explorers now, so i need to know how to make em work on a stock one too.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Paypal is jamest45acp@cableone.net..... make it $110 and it should cover shipping.
On the 1.6's....... the stock rockers are 1.6 ratio but the aftermarket ones are beefier and evedently there isnt much clearance under the explorer covers. Section525 was the one who had clearance issues, but only on one rocker (i think). From what i remember, he tapped a little "clearance dent" and it worked fine.
expo5.0
Red Wing, MN
1996 xlt
sounds good, shouldn't be any trouble then to make em fit for my cousin.
how important to swap to aftermarket ones for him?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Not that important. They are nice, but not needed.
expo5.0
Red Wing, MN
1996 xlt
is there a cheap and easy place/way to buy any gaskets/specialty tools we'll need?
expo5.0
Red Wing, MN
1996 xlt
James, i'm really sorry. i'm out on the cam. i'm having one custom ground locally, along with some other goodies
Status
3 Nitrous Need for Speed! 0
Awon2zip Nitrous 1994 Explorer Need for Speed! 278
1 Nitrous for the first time.... Need for Speed! 45
S Will a stock 5.0 handle a 200+hp shot of Nitrous? Need for Speed! 29
R Pics of my Lincoln LS nitrous setup... Need for Speed! 25
R 2005 Lincoln LS w/ 100 shot nitrous new best ET's 11/18/06 Need for Speed! 13
C nitrous questions Need for Speed! 10
S Nitrous.....Who has it? Need for Speed! 31
K Official 4.0 SOHC Nitrous Thread! Need for Speed! 4
boominXplorer My nitrous purge kit is on! Need for Speed! 5
S Nitrous injector..... Need for Speed! 15
V Question on spark plugs for nitrous system Need for Speed! 8
V Wanting to install nitrous, what all will I need? Need for Speed! 8
E more intelligent nitrous questions Need for Speed! 0
E nitrous with stock fuel... 5.0 x and 3.0 dohc escape Need for Speed! 18
boominXplorer Boomin Gets NITROUS!!! Need for Speed! 39
C Nitrous( beat the dead horse ) Need for Speed! 6
S ZEX dry Nitrous, has got to be a joke Need for Speed! 19
S Nitrous mods Need for Speed! 2
S Nitrous Bottle Openers Need for Speed! 4
S What do you pay for nitrous?? Need for Speed! 7
S Nitrous tips / general info Need for Speed! 20
A nitrous Need for Speed! 12
james t i want my nitrous back! Need for Speed! 22
Alec The nitrous oxide is no more.... Need for Speed! 7
4 Nitrous Express Need for Speed! 6
U Nitrous from the `Stang? Need for Speed! 8
Alec Note to nitrous users Need for Speed! 3
E Nitrous Shots Need for Speed! 4
Alec Project Splat: Nitrous Oxide Need for Speed! 28
Cheeser96 Comp Cam Kit Questions Need for Speed! 3
boominXplorer Comp Cams XE264HR-14 Cam install in my 5.0 swapped 01 Ranger Need for Speed! 57
W 1996 Explorer 5.0 & E303 cam - Do I need to upgrade stock springs? Need for Speed! 5
Dono 4.0 ohv cam specs and discussion Need for Speed! 9
C Cam question Need for Speed! 0
Q '99 ohv 4.0 cam build Need for Speed! 451
S Is anyone running a custom cam in their 5.0? Need for Speed! 3
D 96 5.0 cam question Need for Speed! 9
Dono To cam or not to cam? 4.0 OHV Need for Speed! 221
5 Ford Motorsports E Cam Need for Speed! 8
B Comp 422 cam install= New lifters? Need for Speed! 1
T About to dive into my 4.6L quad cam 93 Ex build Need for Speed! 43
Turdle Cam Talk now--gotta go Need for Speed! 10
V comp cam 410? 422? or delta cam? Need for Speed! 7
T 98 Explorer 5.0 More Power Cam ??? Need for Speed! 5
S Stock 5.0 cam specs ? Need for Speed! 9
U e 303 cam Need for Speed! 8
T Tossing in towel - need Explorer 302 / EEC-V friendly cam choices Need for Speed! 1
Xan Rebuilding the top end and new cam Need for Speed! 11
B Cam Swap, Exhaust headers, and S.C? Need for Speed! 18
Similar threads
