Nitrous Express
4LF
Memphis, TN
'99 Sport
I'm getting a Nitrous Express wet kit in a couple of weeks. I know a 75 shot is safe on most cars- is this true with explorers as well? I have a 4.0 OHV.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
A properly set up 75 shot should be fine. You said wet so it will have fuel to go with the n2o. Have you given any thought to the spark timing? The computer can adjust the timing to a degree, but you may find that you need a custom burned chip or other method to adjust the timing when you're using the nitrous.
Also I'm curious as to how you're setting up the fuel system since your 99 doesn't have a fuel return.
4LF
Memphis, TN
'99 Sport
I haven't taken a close look at it yet. I'll be sure to post how I do it. It WILL have a wet kit- I'll install a seperate fuel cell/fuel line just for the nitrous if I have to. Any chip you would recommend?
BTW- I need to get rid of the speed governer :D
frj00
Allentown PA
99 Sport 4wd 4.0 SOHC
how do i get rid of the speed govener and find a wet nitro kit? What's the diffrence from regular set up like a profogger into the intake?
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
People are saying good things about the Apten chip that's being sold here, maybe he can program you a "flip chip" for use with the N2O.
As for nitrous setups frj00, you'd want a single port injection system in the intake between the MAS and TB. I have a 70 dry shot and up the fuel through the "stock" system via an adjustable regulator.
4LF
Memphis, TN
'99 Sport
Nitrous Express makes a kit- I would have ordered it last week, but my dog had puppies and needed a (very expensive) c-section. You can tap any fuel line for it (doesn't have to be a fuel return line)
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
I know you can tap any fuel line, but I've heard a fuel return is almost necessary. This is because when you let off the nitrous, the excess fuel in the system has to go somewhere.
