Nice looking truck! (avatar)
10's ?
You better just save $100.00 to give to him.
I think Troll was the fastest explorer ever documented on this forum and if I recall correctly it was in the 10,s. I don't think any other explorer ran 10's.
Of course if you are talking about 1/8 mile I will just put my foot in my mouth, at least I have clean socks on today. lol.
In all seriousness they make kits for specific vehicles that supposedly don't need any tuning. You could get one of those to put on the 4.0L but it might not have the best results with the 5.0L and tuning might then be required.
I have started looking into this a little since I am planning on using nitrous this coming year. In an explorer where the back is like a hatch back or wagon where there is no trunk you have to have a blow down tube to vent the nitrous outside the vehicle if the bottle pressure gets to high. I recommend only buying the bottle from a reputable seller so you know no one messed with the pressure relief on it. Just look up nitrous tank explosion to see what a bottle can do to the back of your vehicle if it ruptures do to over pressure. Normal pressure is around 1,000 psi in the bottle.
Also you will need a fire extinguisher as a wet system mixed with a backfire will toast a few things under the hood, and the whole vehicle if you don't get the fire out. Just look up nitrous backfire for that one.
Both of those things are probably mandatory to race at you local track, you will probably need a fire retardant racing jacket as well.
Thanks man, I actually like you Ex a lot too, it is also the inspiration for my next project. As far as the one in my Avatar, she is my DD, so I don't play with her too much. I know I can get it down into the 10's with a lot of power, and less weight. It will just take me a while. Since not a lot of guys on the site here have a track setup for NOS on their trucks, I have been looking at the competition, the TBSS forums, and asking questions as far as NHRA legal setups. This summer is going to be a basic setup, with a stockish 302, suspension, and brake work, along with some weight reduction, I am hoping to low 14's, possibly 13's, the following summer will introduce a 4 link in the rear, and a more permanent engine/trans combo. and the rest is up in the air. End goal is obviously 10's, and I will get there, but I also want a truck I can drive on the street to shows and such, the street racing scene is huge around here, and I want to confuse some people with my truck also.
Wet systems are actually the best,.
as the nozzle not only injects the n02 it feeds the fuel it needs too,
although a bit complicated they are fairly safe if you do it properly,, make sure it gets the fuel it needs,leaning out one of these is spendy ,,
I have been reading a lot, and it seems that tuning, although expensive, is cheaper then blowing up an engine, so that might be what I do, but It will have to be on the 302, so that's fine, it just means I have to do the engine swap first.
