Nitrous from the `Stang?
uturnoneighty
Sulphur, Louisiana
2002 Explorer Sport
I have an Edelbrock dry nitrous kit(75hp) that was on my Mustang before supercharging it and I want to install it on the Exploder!! My question is this, would it work with the factory non-return fuel system. Everything looks like it would work, only minor modification I think it needs it an elbow coming off the scrader valve on the fuel rail for the safety switch. Buying a 4.0 specific nitrous kit is not out of the question though, whatcha` think¿:confused:
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Dunno if you can expect the computer to handle the quick decisions to really up the fuel that much when you hit the nitrous. With a totally dry shot, you'll fry your motor.
uturnoneighty
Sulphur, Louisiana
2002 Explorer Sport
Suggestions please!!! You seem to speak from experience!!;)
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
i wouldnt do it.... nitrous takes a lot of time and effort to fit onto a non performance vehicle..... a musstang engine is not the same as an explorer engine, no matter how SIMILAR they may be....
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
to make a dry kit work you'll need a custom computer 'flip' chip. this is a chip with a normal setting and a nitrous setting. you'll set the nitrous setting to retard timing and add fuel so you don't fry the motor.
uturnoneighty
Sulphur, Louisiana
2002 Explorer Sport
Thats no problem, as I have a "Smart Spark" computer that will do that for me as well as turning on the nitrous at a set predetermined rpm. It too was on the `Stang before I put the programable DFI on. It allows me to pull out or add timing every 500 rpm. I will also add a stand-alone stoich meter to monitor air-fuel ratio. I am convinced it will work, if the stock fuel pressure/volume can handle it. One short "blast" long enough to measure the detonation and fuel ratio shouldn`t hurt it. I am more worried about a "sneeze" that will lift that cheap plastic intake! :( The truck has 4300 miles on it and if something happens, I`ll just remove the juice and have the dealer fix it under warranty( except the intake).
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Without a special computer program and with a totally dry setup, the truck can probably only handle a max of 55 shot.
uturnoneighty
Sulphur, Louisiana
2002 Explorer Sport
I`m not intending to set the world afire! 50-70hp is all I need to make a few take notice. I think that 6-10 second "hits" is long enough and safer. Thanks Alec for your input.:bounce:
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
np, good luck
3 Nitrous Need for Speed! 0
Awon2zip Nitrous 1994 Explorer Need for Speed! 278
1 Nitrous for the first time.... Need for Speed! 45
S Will a stock 5.0 handle a 200+hp shot of Nitrous? Need for Speed! 29
R Pics of my Lincoln LS nitrous setup... Need for Speed! 25
R 2005 Lincoln LS w/ 100 shot nitrous new best ET's 11/18/06 Need for Speed! 13
C nitrous questions Need for Speed! 10
S Nitrous.....Who has it? Need for Speed! 31
K Official 4.0 SOHC Nitrous Thread! Need for Speed! 4
boominXplorer My nitrous purge kit is on! Need for Speed! 5
S Nitrous injector..... Need for Speed! 15
V Question on spark plugs for nitrous system Need for Speed! 8
V Wanting to install nitrous, what all will I need? Need for Speed! 8
E nitrous cam, and in-car cam swap info thread Need for Speed! 15
E more intelligent nitrous questions Need for Speed! 0
E nitrous with stock fuel... 5.0 x and 3.0 dohc escape Need for Speed! 18
boominXplorer Boomin Gets NITROUS!!! Need for Speed! 39
C Nitrous( beat the dead horse ) Need for Speed! 6
S ZEX dry Nitrous, has got to be a joke Need for Speed! 19
S Nitrous mods Need for Speed! 2
S Nitrous Bottle Openers Need for Speed! 4
S What do you pay for nitrous?? Need for Speed! 7
S Nitrous tips / general info Need for Speed! 20
A nitrous Need for Speed! 12
james t i want my nitrous back! Need for Speed! 22
Alec The nitrous oxide is no more.... Need for Speed! 7
4 Nitrous Express Need for Speed! 6
Alec Note to nitrous users Need for Speed! 3
E Nitrous Shots Need for Speed! 4
Alec Project Splat: Nitrous Oxide Need for Speed! 28
Similar threads
