no 1st gear ranger4.0 auto
1996 ranger
Bristol
1996ranger4x4off road
same problem as vinney3k and merald have
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Did you mean to post this as a response in a thread? We don’t know what problem vinnie and merald had.
Please either give a link to that thread, or full info on the problem you have.
1996 ranger
Bristol
I have a1996ford ranger automatic 4.0 4x4.Every gear works except 1st. I pull out in 2nd then put the shifter in drive and its fine until i have to stop at which time i have to drop it down in 2nd to get moving again .Reverse also is fine. I read that other guys had idenical problem and was hoping somebody figured out how to fix it.Thank you very much for any help or ideas on correcting my problem.Also read to check fuse #27 but it was good
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Okay, your 96 4.0 Ranger should have a 4R55E trans.
First, hows the fluid level? Fluid color?
Did this problem just start?
Moving this thread to the transmission section.
transman304
Morgantown WV
2004 Chrysler PT Cruiser
As @RangerX mentioned check the basics first. The symptoms you described are what would expect when the OD sprag fails but that usually will effect reverse also. Is the OD light flashing?
Brad
1996 ranger
Bristol
i bought the truck 3months ago and it was like it is.Changed trans fluid and filter but still same problem
