RoRosMachine
- August 19, 2013
- Pawtucket, Rhode Island
- 2003 Mazda B-3000
Curious what would cause the intermittent loss of 1st(reverse works fine) in a 5r44e ranger??? when 1st does work, after revving lightly, it bangs hard and then 1st gear works fine....otherwise you have to take off in second..Could it be the 1st reverse servo at valve body...??? All Fluid has been flushed, new filter and she shifts fine thru all other gears including overdrive(no check engine light either) ....Any suggestions
