mitch
- January 2, 2004
- high point, NC (home) charlotte, NC (school)
- 94 limited
My 94 x doesn't have 4 wheel drive, and i have researched all the threads. It is not the t-case or the auto hubs b/c when the dash push button is turned on you hear the clicks for the hubs and both drive shafts turn when its in drive and reverse. However the shaft that is between the front and rear traction beams that connects the differential to the other tire I dont know whats it is called doesnt turn which must mean that the gears in differential aren't turning or are chiped or something. If anyone knows if this is why my 4wd is not working or if something else is wrong with could tell me it would much appreciated. and also what will it cost to fix the problem
thanks mitch
thanks mitch
