Wiley1
- December 11, 2009
- Norwalk, Ohio
- '01 Sport, 03' XLT
03' explorer... Brake lights went in a strange way. Day before yesterday was having problems getting the gear shift interlock to disengage. Discovered last night that when I pressed lightly on the brakes I had break lights but when I pressed harder, break lights went out. When the brake lights were on the gear shift interlock would disengage & vice-versa. Soooo, I pulled the plug to the stop light switch on the brake pedal & plugged it back in. No brake lights, period, after that. Checked every single fuse in both boxes (found 1 blown and replaced it) but still no brake lights & no shift. Replaced the stop light switch. No brake lights, no shift. Checked the plug going to the SL switch, it has power. Checked the continuity of the SL switch, checks out ok. Would a bad gear shift interlock solenoid be causing the problem? I'm at my wits end.
