No brake lights/ to turn signals. | Ford Explorer - Ford Ranger Forums - Serious Explorations
jhawaiian23
2007 Ford Explorer
I have an 07 Ford Explorer XLT. The main issue I am having is: my brake lights and turn signals do not work in the rear. Which is cause the car to not come out of park. I can get the car our of gear by bypassing the safety switch under the cup holders. However, I do not have voltage to my back lights at all. I have tested for voltage when the brakes are depressed, I get nothing. I get 12 volts when the headlights are turned on and the running lights in the back are work. The bulb also illuminates when the halo lights are on. But I have no brake lights or turning signals or flashers (when depressed). I have checked all the fuses, they all pass, both Ohms and Diode tested. I have replaced the brake switch, which I might have received a bad one, after testing the old one. I am lost and have no idea where to look next. I started hand over handing the wires from the rear light, but I only made it through to the middle seat.
Does any have any ideas, because I am lost. Thank you.
Bill MacLeod
Hamilton, Ontario
06 Ltd V-8
Do you have power to the Brake Pedal Position Switch? Wiring diagram (2006) shows a brown/red stripe wire from the smart junction box (SJB) to the brake pedal switch.
