mr_valingo
- January 21, 2011
- Madison, wi
- '95 sport
ive got a 95 sport with a newish starter (4-5months old). above 0 degrees F it will crank over and run fine. if it drops below 0, however, I only hear the click of the solenoid on the starter. no crank. if I heat the starter up with a torch, it'll fire right up. last night I pulled the starter and tore it down, cleaned, and reassembled. everything went well and looked good until I tried to start the truck and the ignition wire to the solenoid started on fire. ok...pulled the starter back out. tested it with a jump pack and it functioned perfectly. put it back in, ran a new wire to the fender solenoid, and it fired right up. but again this morning in the -30 windchill crap weather....just clicked.
Any thoughts??
Any thoughts??
