BadaBingM3
- December 18, 2011
- Las Vegas, NV
- 1999 4WD 2DR Explorer
So I got a new Long block from Powertrain Products and comes with a new oil pump and strainer with a new gasket for the strainer to pump but there is no gasket for the pump to the block base where it mounts with two bolts. There is a small white plastic ring gasket but does not seem to fit anywhere properly. Hayne's manual says to replace with new gasket when reinstalling the pump. I've searched high and low and also went to my local Ford dealership and they provided me a diagram and there is no gasket shown for where the pump mounts to the block. Anyone know if this is correct? Or is there a gasket that goes there? When I removed the old pump from my old block, I do not recall seeing a gasket there. I just need to be 100% sure before I drop this new engine back into my explorer. Please see attachment. The picture is supplied from Ford and is upside down but I drew arrows to where Hayne's manual says to install a new gasket. Cheers!
