Russ in CT
- November 11, 2002
- Milford, CT
- '99 XLT
First winter with the new '02 EB Ex (with dual climate control), and I find the heat doesn't always work. Sometimes it does, sometimes it doesn't. I don't hear any clicking or clunking that I've read is indicative of a stripped blend door actuator. Over the summer the A/C seemed to work fine.
When the heat is working, when I put it on Auto the heat only seems to come out of the vents by your feet, never from the dash vents, and it isn't all THAT hot even when its working.
It usually seems to start out working, and just gets colder and colder as I drive, until it feels warmer to just turn it off. Leaving it off for a little while then turning it on again typically it'll 'work' again for a while.
The engine temp gauge does not vary at these times, once warmed up it sits right in the middle of the gauge.
