DaveWC
- January 4, 2007
- Independence, MO
- 1997 XLT control trac 4wd
I recently repaired the blend door so this past summer I could use the AC without having to have it on Max all the time. Since then, I seem to have lost my heat. I opened the radiator yesterday after work and it looked as though the water pump wasn't circulating. It isn't overheating or even running hot. I have one hot hose and one not so hot hose at the heater core. The upper rad. hose is hot as it should be, stat is working, the lower rad. hose is not hot at all. I asked the mechanics that I work with at the shop and none had heard of this problem. Has anyone here encountered this? Help, it is starting to get cold here in Independence. Thanks, DaveWC
