thor1701
- April 24, 2007
- fresno ca
- 96 EB
seem to have an interesting problem, i'll start with the heat first, i have no heat, all it blows is room temp, no matter what setting i have it on, heater hoses get nice and hot, heater control valve seems working fine, no weird clicks or noises behind the glove box, all fuses are fine, and no codes showing up on the EATC when put into diagnostic mode, now with the a/c part, same thing, room temp, a/c clutch does not engage, and i am only measuring 4 volts from the connector at the clutch, i have a fully charged a/c system, i have also tried the bypass method of getting the clutch to turn on by jumping a pressure switch, still nothing, only thing i have not done is find a way to directly connect the clutch to the battery and make it engage that way
this is on a 96 eddie Bauer explorer 4.0
