97exploder19
- April 20, 2010
- 99 Limited 5.0
Got a little problem Id like to solve before winter comes. My 99 5.0 will have good heat while driving, but if the truck is sitting at idle, I have no heat or luke warm heat.
Also I noticed I have a coolant leak right under the engine. It only happens when I have the coolant reservoir filled. The reservoir and lines arent leaking. Any ideas what it could be?
Last year before winter I replaced all rad hoses, bypass hose, thermostat with an OEM one, and changed coolant. The temp gauge needle is always in the center of the gauge.
