jaredlangston
- July 27, 2004
- Columbus, Oh
- 99 limited
No heat from VENTS and FLOOR!
Here's what's going on. I have a 99 explorer limited sohc 4.0. This has all the electric heat and a/c contols.
My problem is that I only get heat or a/c from the defrosters. No matter what setting I have it set to.
My a/c only kinda works never blows really cold air.
Also my heat has to be on the hottest setting 90 degrees to even blow heat out. Same thing with A/C only on the coldest setting. The heat gets very hot. But its either that or no heat.
No problems with overheating.
Rear vents work and rear defrosters work.
When either the heat or the a/c is on I hear a clicking sound from under the driver side of the hood. The clicking sound is about every 15 seconds. When I turn the heat off it immediately goes away.
I have looked up stuff hear and saw that it is probably the blend door. I think I can do the "nail trick". It could also be a vacuum problem. I have no idea where to look for that. But it seems like there is more to it than just that. Any photos or links would be great!
Any Ideas?
Thanks Everyone
Jared
Any Ideas?
Thanks Everyone
Jared
