no horn? | Ford Explorer Forums - Serious Explorations
no horn?
texasislandboy
San Antonio
sport 2001
pulled the cruise control bottons from the steering wheel and now the horn isn't working just wanted to see f anyone had that problem should I just order new cruise control buttons and put them in?
looked at fuses and they were good
Was the ground wire screwed back tot he wheel? (black single wire, mounted under switch, held with screw that held the switch on)
pulled the airbag and looked again didnt see any wire for a ground i did pull the wires for the cruise control tho so i think im going to order the new buttons and wires
The harness coming from the clockspring that the cruise plugs into has them. When you push the airbag cover down, that completes the circuit with the wires that plug into the airbag mount (the single black wires). If the wire isn't plugged in, it isn't a circuit, and thus no horn...
These have to be plugged in:
