No Low Beams in Auto Mode
Looney
2004 Sportrac
I've been lurking around for information but thought I would throw this out here to see if anyone has run across it before.
2004 Sportrac XLT - When the headlight switch is in the manual mode all lights work, low beam, high beam, park, fog and cluster. With the switch in the AUTO position I can cover the sensor and I hear the relay energize and all of the lights come on except for the low beams. If the switch is in the AUTO position and pulled out (turns on the fog lights) then all lights, including the fogs come on except the low beams. The high beams work in either AUTO or Manual.
It appears to me that both positions use pretty much the same path. Any ideas?
