Fossiljager
- October 19, 2009
- New London, New Hampshire
- 90 Bronco II 4.0L/A4LD/
Hi guys,
I built a 1990 B2 using 94 explorer guts, built 4.0L, built A4LD, transfer case that came with the Explorer. I've downloaded and read everything I could find on diagnosing and repairing the push button 4x4 system on this vehicle. I have hi range by pushing the 4x4 button on the controller. (not lights) But I do not have low range or any of the indicator lights on the instrument panel or the in lights that appear in the hi-low range controller. All the bulbs are good. I have diagnostics that show the light will come on if I jump the appropriate leads at the module. BTW, I have three modules that all check out 100% . I have run self diagnostics on each one. They all blinking 4 times indicating they are fine. There is a white/blue striped wire that plugs into the controller in the dash that runs to the fuse box. I ran a continuity test from the controller back to the fuse and got tone. When I tested for voltage coming from the fuse to the controller, I got no volts at all. This make no sense seeing it just past continuity. At this point, I'm stumped. Any suggestion would be helpful. One question, is there a 4x4 relay under the dash that might be the culprit?
Thanks guys..
Thanks guys..
