No power detected 2020 factory installed 7-pin connector. | Ford Explorer - Ford Ranger Forums - Serious Explorations
jragones
PORTSMOUTH
2020 Explorer Platinum
Is 12v power supplied full time on a 2020 Explorer factory installed 7-pin towing electical connector? My Echo bluetooth brake controller requires 12v power as does emergency braking battery. I cannot detect power and LED does not show connection when plugged in. Does the power mode need to be selected to "towing mode" and a trailer connected for it to send 12v power to power terminal? Far too complicated IMO.
Dale5403
Mondovi, WI
2020 Explorer ST
Check fuse #57 under the hood. If it's good you might need to check with your dealer.
jragones
PORTSMOUTH
Thanks. I'll check. car is a month old... crappy fuse then. Ha ha
Dale5403
Mondovi, WI
2020 Explorer ST
Or if it's not there. I've seen this issue else where but the OP never reported if he got it resolved so I'm guessing here. I don't tow with mine so I've never checked it.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
jragones
PORTSMOUTH
Fuse there and I good. Cap world guys said he always has to run a power wire to the 7-pin black power lead point when he installs hard wire brake controller. Going to check with Ford...
Dale5403
Mondovi, WI
2020 Explorer ST
