srtorres22
- September 6, 2012
- Rogers, Arkansas
- 1998 Ford Explorer
Good afternoon,
Earlier today I tried putting a piece of copper on the passenger side dome light since the original copper piece was in pieces hoping of getting the driver side light to work. Well, it didn't work now I'm stuck with out power to all four windows, the 4x4 switch won't engage. However the hi and low do flash synchronize randomly. Also, the moon roof no longer has power as well. I checked all the relays and fuses and all seems to be in working order. I can't seem to pin point the source of the failure. If all fuses and relays check out then I have no idea on what other issues could be. Everything worked fine up until I decided to attach the copper piece to the dome light. Any help will be appreciated.
