donaldthacker
- October 4, 2004
- va
- 99, sport w/35" MTZ's
a few weeks ago I lost reverse. with glaciers help I found the problem to be the reverse modulator. I cleaned it up and put the superior kit, knowing that I needed to located a better valve body due to some damge I saw in the associate bore. well the tranie worked fine and I finally got a good used valve body. I went throught the new used one same as last time with the superior kit and ford upgrade, put it all back in and still no reverse. I checked all of the soleniods and they fell within the ohms listed in the diary. I still have forward gears but no reverse. one question I do have is when I pull the valve body what position should the reverse servo be? by this I mean up in the bore or down near the plate. I do not know if it means anything but was just curious.
I have checked and changed just about everything listing in the diary, even the dtr, so any advice?
