No Sound - Sync | Ford Explorer - Ford Ranger Forums - Serious Explorations
No Sound - Sync
voltch
Atlanta, Ga
2013 Ford Explorer XLT
Trying to find out some info about an issue im having.
My wife normally drives and she heard a pop one day, that sounds like a speaker pop.
After that no sound coming from the speakers, no sound from radio , no sound from bluetooth calls , etc.
Im thinking maybe there is some amp that drives the speakers that could have gone bad or is everything integrated into the sync touchscreen unit as one?
I tried pressing the radio power button a few times and it gave the same loud "pop"
Can someone can help point me to a thread or repair for this type problem before I go to the dealer?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
It sounds like it could be the Audio Control Module (ACM) that has gone bad. If it is, then it likely has to be replaced.
voltch
Atlanta, Ga
would you happen to know the part number? when I search on ebay it keeps coming up with something to do with an airbag.
jmr061
Wisconsin
16 Exp Sport
If you provide me your VIN I can give you the exact part # of the ACM yours was built with.
jmr061
Wisconsin
16 Exp Sport
I received your VIN and the ACM it was built with is part # DB5T-19C107-DD.
voltch
Atlanta, Ga
Great thank you. Do you know if there is any type of programming needed or can I just swap the part out and it would "work"
peterk9
Staff member
Moderator
Callsign
VE3
Keep in mind that the thought it may be the ACM is just that. Can't say for sure. Not sure about any possible programming requirement. Perhaps Jason would know.
voltch
Atlanta, Ga
Hi just an update, I went ahead and brought the truck in to the dealer for service because it was saying that there was an extended warranty for the my ford touch apim for my vin according to the ford owners website so ill wait and see what they say.
voltch
Atlanta, Ga
So Im back from the dealer, they want $1000+ to repair. They told me that the APIM needs to be replaced.
I had an extended warranty on it , but it expired in april of this year.
Is this something that I can source myself on ebay or elsewhere? ( I saw some kinda pricey on ebay for $699! Sheesh) Is there any programming needed?(if so is there a programming guide)
I may be asking for a stretch but is there some common component in these that commonly fails that I may be able to make a simple repair my self (like bad solder joints or caps for example)
peterk9
Staff member
Moderator
Callsign
VE3
You can try contacting Jason, jmr061 by PM and see if he can help.
voltch
Atlanta, Ga
Everything is fixed on this issue now. The problem was a bad ACM.(The dealer was wrong) I replaced it with a used one.
Thanks Jason and Peter for the help!
