GuidoTSi
- December 4, 2009
- Denton, Texas
- 1993 XLT 4x4
93 XLT auto 4x4. Had a coolant leak around passenger side valve cover @ thermostat. Took top half of engine apart (valve covers, upper and lower intake manifolds) to replace gaskets. Got it all back together, but I now have an extra connector hanging free.
Looks exactly like an injector connector, but all injector connectors are hooked up. Truck will crank but will not start, pulled #5 spark plug to check spark while cranking. Fuel present, but no spark.
During cranking, the KOER tests seem to run, which is where I get the 513 (PCM internal voltage failure) code. I pulled the PCM to check it, no leaking capacitors or anything like that, looks brand new. Which brings me back to the "extra" connector. For the life of me I cannot see where it should connect, but from looking at all the wiring diagrams, including this one, I suspect it's for the PCM relay.
Any assistance would be great, having the truck down this long is a real cramp for work.
