No Start Issue - Injectors not firing
old_manXJ
96 Edie Bauer 5.0L
I've got a 96 Ford Explorer with a 5.0L. It failed to start for my daughter after sitting for 30 minutes. It cranks fine but does not fire. It is not getting any fuel. I can spray carb cleaner in the intake and it fires up and runs for a few seconds. I have fuel pressure at the shrader valve on the injector rail.
Is there any common fault that will cause a loss of injector drive other than the ECU? I haven't even had a chance to check the fuses yet.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
Are you getting spark? I would check the coil first.. check for any cracks or loose connections.. If the coil checks out fine I would check for spark at the plug.
budwich
Ottawa, Ont
96 XL
It is likely that you "lost" your cam shaft position sensor which "tells" PCM to "squirt" the injectors.... wire... ground ... or sensor itself.
old_manXJ
96 Edie Bauer 5.0L
Wouldn't that also screw up the ignition timing, which is fine?
budwich
Ottawa, Ont
96 XL
nope.... that is derived from the crankshaft sensor.
dynamite196
Glastonbury, Connecticut
97 Sport
have you tested to see if the injectors get a signal to fire, i believe it's a 12v pulse that fires the injectors. start there and let us know what you find.
