Mesozoic
- October 3, 2015
- Tucson, AZ
- '00 Mercury Mountaineer
Today I took some time off of work to go title and register my '00 Mounty (bought it last Thursday). Parked at the title agency and when I came out to return to work, everything was dead. The THEFT light was blinking slowly, but the voltmeter was indicating full low. I called a coworker and we jumpstarted it, let it run for a while, voltmeter was indicating somewhere in the middle of its range, and eventually the truck made it back to the office.
Before turning the engine off, I measured 12.8V at the battery terminals. Turning the engine off, I also saw 12.8V at the battery terminals. So... there may be an alternator issue, possibly, but I decided to charge the battery for about 5 hours and return later.
So, I returned 5 hours later and the battery is looking ok in terms of voltage. Tried to start it, and same behavior as before: THEFT light blinking slowly, full low indicated on voltmeter, multimeter reading about 13V at the battery terminals (even while turning the ignition switch to crank). I then tried to jumpstart it with my Bronco, running an Optima deep cycle and 3G 140A alternator. No dice, voltage at the battery terminals reading 14.1V, but nothing inside the Mounty, no lights, nothing.
I checked underneath the Mounty to see if maybe the starter power cables had been cut or damaged or loose, but everything looks fine. I followed the Ford procedures found on this website, including swapping the starter motor relay with the blower motor relay and I verified that pin 85 of the starter motor relay is getting 13V during key on. I probed every single fuse in the internal fuse panel and the power distribution box and everything is looking ok.
Not sure where to look next. I was starting to think that maybe I had a power diode problem of some kind, but that's just a guess. Anyone have more experience than me with a 2nd gen?
