Joatman24
- July 25, 2008
- Ontario
- 01 sport trac
No start, theft flashing...updated, need ford pro
This has happened twice now, and would like some input. Go to start 2001 Sporttrac and it will start and die about 4 times, then just turn over(crank). the theft light continues to flash while the key is on. If i leave the vehicle for 5plus minutes, it will start no problem. I have come to realize that if i put the key on and the theft light goes out, there will be no problem starting, it the light continues to flash, it will crank but not start. I have done some research and have found info indicating that if the anti-theft system is activated that it should not even crank? I check the fuel reset, but it is not triggered, and if it was i guess it wouldnt start after 5 minutes. Hoping to resolve so i don`t get standed one day. I have also tried the spare key, when it wouldn`t start and the same problem. It does not have a remote start system. thanks pat.
