MLMcG
Warren, MI
2002 Explorer
2002 Explorer
Happened suddenly. Pulled into my driveway, shut off vehicle before realizing I had to roll up windows. Turned key forward, and all electricity cut out.
Keeping key inserted without turning, I have very limited electricity: car beeps with car door open, power outlet works, THEFT light blinking on dashboard (NOT rapidly, about every 2-3 seconds - Could this be the issue? I swore this was normal)
Headlights & Radio do not work. Putting foot on break causes ALL electricals to stop working.
Bought a brand new battery & terminals just a couple months ago, so no corrosion & tight on battery.
Doesn't take a jump.
Cannot shift out of park at all.
During the drive just before this occurrence, I did notice the gauges acting funny for a second, but went back to normal.
I have recently been having issues with my power locks, automatically locking & unlocking on its own, in spurts.
No fuses APPEAR to be blown
Bringing a voltage/light tester home from work today to test battery and fuses
I have very limited knowledge of vehicles. Please halp.
MLMcG
Warren, MI
2002 Explorer
Battery is good...
MLMcG
Warren, MI
2002 Explorer
Battery is dead or connection to battery is bad.
Have someone here to help me out. He tested voltage to the starter and its reading good. Does this rule out connection/battery issues?
TechGuru
Location
Texas
2003 XLS 4X4 4.0L FLEX
Sounds like you have voltage but no amps. Again connections or battery.
Turn the headlights on, what do they do when you attempt to start it?
Unless you own a load tester, take the battery out and take it to AutoZone/OReilly's for testing...
Do the battery cables get warm/hot after trying to start it? If so then you have a shorted out starter.
MLMcG
Warren, MI
2002 Explorer
Battery tested good at O'Reillys
All electricals return to vehicle after leaving battery disconnected for a period of time.
Attempting to start, I hear one click, and then everything dies again.
Shortly after, the limited electricity returns (door chiming, charging port, slow blinking theft light, flickering radio light)
I have not noticed the cables getting warm
Also - Headlights worked when full electricity came back, but not with the limited electricity situation.
TechGuru
Location
Texas
Check negative terminal connection to body/transmission for corrosion and also positive connection at starter.
