SammyM00782
- July 18, 2014
- Ewing, NJ
- 1994 Ford Explorer
Good evening everyone. Boy do I have a doozy for you today
So last weekend, I noticed my 94 XLT wasn't applying the converter clutch after doing some lighting upgrades. It was suggested to me to remove everything I did and try again. So I did that, to no avail. Now here's the real problem I can't figure out. If the truck is jacked up in the rear, freewheeling, the PCM will send 12v and command lockup . Put the truck on the ground, no PCM command. I had a DPFE code that I took care of, OHM tested the ECT sensor which is working fine, BOO switch is working fine, replaced the VSS sensor because when I went to go test mine it was filled with trans fluid. Also found I had a bad set of plug wires so I did that too while it was in the garage, could have possibly been messing with the PIP signal.... I'm literally out of ideas here as to what the hell is going on. I noticed tonight though after a coffee run to Wawa, I jacked the truck back up and this time I got no command for lockup. It seems to just work when it wants to, as long as I'm not actually driving. On a side note, I was getting the lockup command when the truck was still pretty cold so I don't think it could be a temperature issue. Thanks everyone.
