Stick4503
- December 12, 2011
- Winder, Georgia
- 1996 & 2004Explorer 4x4
Please Help with 5r55s transmission
So as you can see above I went from a flashing OD light, to finding a damaged spot on the separator gasket. Replaced separator gasket and fluid, to broke pump.
Now I have installed re-manufactured. Pump, another new filter, new fluid and an inline filter coming from the radiator/trans cooler back to transmission and new converter.
Truck is now going down the road on its own. Seems to shift OK. NO OD light flashing, HOWEVER--
I now have a whine / growl noise at shifts. This most of the times happens on medium to hard accelerations. No noticeable noise at idle.
Don't want to put words in ones mouths but could this be something to do with the in line filter? Or what do you think? Sounds a little like pump cavitation but I'm not sure.
The filter is a inline transmission filter. Will have to get the make but it is for transmission fluid and is to some degree a magnetic type filter.
It is a raybestos powertrain magnetic inline filter and Looks pretty much like this one.
(dead link)
(dead link)
