Noise on cold starts | Ford Explorer - Ford Ranger Forums - Serious Explorations
renda10
Ontario
2002 Explorer Sport
hey guys. i am new to the site. when i start my truck om cold starts or after the truck has been sitting for a while i get this noise which sounds like a pully. the drive belt is new. what could it be?
mab668
manalapan mj
2004 xls
i just had this same problem turned out to be a combo between the old belt and the idler pulley. if you take the belt off and turned all of the pulleys by hand. you should be able to feel witch pulley is bad if any. or you can try belt dressing as a quick fix
renda10
Ontario
2002 Explorer Sport
how would i know what pullys are bad?
mab668
manalapan mj
2004 xls
take the belt off and turn the pullys by hand you will feel if there is a bad pulley
97awdx
Lake Wallenpaupack, PA
1998 XLT
Are you sure it's not a timing chain rattle, belts usually make noise all the time. Timing chain rattles on cold starts are common with the 4.0
muzic101
Willingboro,Nj
2004 Eddie Bauer
Remove the belt check all pulleys the belt drives.
1. Alternator
2. Idler Pulley
3. Tension Pulley
4. Power Steering
5. Water Pump
Here is what to do. Spin each pulley and listen for grinding noise.
Note: Power Steering pulley will not turn as free as others due to slight pressure in pump housing.
Capt'n Morgan
Southeast Michigan
05 Limited V8 AWD
Had the squeaking on my 05, shop says it's the alternator, and they are replacing that. $325. :(
