noise/rattle behind tachometer and speedomoter???
rockey95
Mississippi
Folks, i've got a 2010 Ford Explorer XLT 4.0 V6 and have owned it about 1 year now. Love the vehicle but have a question, every time i crank it up in the mornings there is a noise behind the dash and seems to come from behind the tachometer and speedometer, mostly behind the tach, not really sure how to explain the noise but it happens every time i crank the car and after a while it seems to go away. Almost as if something is running behind the console.
Could anyone shed any light on this for me?
Thank you
07EddyB
Bowling Green, KY
2007 Ford Explorer 4.6 V8
The only thing that jumps to mind is that it is possibly a actuator on a blend door in the dash. I'm not aware of one behind the tach so this would mean you're off on where the sound is coming from. Try making sure your climate control is off before you start the vehicle and see if that changes anything.
rockey95
Mississippi
i will make sure that i check that, i think i have had it off before but will for sure make it off when i start it up tomorrow.
thanks
autobahn
Cologne
2007 Ironman
Hi,
we were having the same problem with our 2007 Ironman, but gave up on it years ago. Sound is def. coming from behind the Speedo-/Tachometer. Sounds like a rocking chair on plastic floors, or a plastic chain pulled slowly through the dashboard. First I thought it was the dreaded rear timing chain rattling close to the firewall, but since it was not rev. related it had to be something else. One weekend I rode in a friends Nissan car, which does a self check of the dashes Speedo/Tachymeter cluster when u turn the ignition on, and it did the exact same thing. The noise sounded just the same. So I think it has to be some part in the cluster that causes the noise. Its been years in my Ex ever since, and everything is still working fine, so probably nothing to worry about.
Cheers,
Andre
rockey95
Mississippi
i did notice this morning that it was growling again behind my speedometer/tach but noticed when i turned my temperature gauge from cold to hot it actually stopped then started again once i turned it back to cold, any ideas folks what this is?
09 EX 4x4
So Cal
2009 Ford Explorer XLT
I have the noise on my 07 sport trac from behind the tach area in the morning when its cold. Same thing as rockey95 when I turned the heat up the sound stopped but in my case it didn't come back when i turned it back to cold. I think it may be the blend door motor moving for some reason. Anybody know how to fix this?
J Rattle noise at startup, 2000-3000rpm acceleration on '06 4.0L SOHC Explorer Stock 2006 -2010 Explorers 5
G Rattle noise in roof Stock 2006 -2010 Explorers 2
M Steering wheel click/rattle noise Stock 2006 -2010 Explorers 21
B Whistle/Rattle noise Stock 2006 -2010 Explorers 0
T bad bearing like noise in front Stock 2006 -2010 Explorers 7
S Strange "whale moaning" type noise from driver's rear area. Stock 2006 -2010 Explorers 4
I Humming or Roaring Noise Gets Louder with Speed Solved Stock 2006 -2010 Explorers 2
M Front Wheel/Axle Noise Stock 2006 -2010 Explorers 5
L Can't find where the noise comes from Stock 2006 -2010 Explorers 2
D Noise from factory headunit Stock 2006 -2010 Explorers 2
P Knocking noise 4.6 3v Stock 2006 -2010 Explorers 11
H 08 mercury mountaineer front end noise Stock 2006 -2010 Explorers 5
M 2010 Mountaineer noise coming from Driver Front Wheel under braking Stock 2006 -2010 Explorers 9
G Strange Noise Stock 2006 -2010 Explorers 2
V Popping noise from front end? Stock 2006 -2010 Explorers 1
J Clink noise from front end Stock 2006 -2010 Explorers 2
K Osilating "thruming" noise in turns. Stock 2006 -2010 Explorers 6
S Noise when Accelerating. Stock 2006 -2010 Explorers 1
S Noise when slowing down Stock 2006 -2010 Explorers 4
J 2006 4.6L V8 XLT whining noise Stock 2006 -2010 Explorers 1
B Rhythmic noise coming from rear driver side Stock 2006 -2010 Explorers 7
S 2006 4.0 Timing Chain Noise? Stock 2006 -2010 Explorers 10
W 2007 Explorer grinding noise Stock 2006 -2010 Explorers 3
S '07 A/C makes a intermittent groaning/howling noise Stock 2006 -2010 Explorers 1
P 08 Ltd 4.6L Front drive line buzzing noise/vibration Stock 2006 -2010 Explorers 6
P 08 4.6L engine ticking noise under load. Stock 2006 -2010 Explorers 10
M 2008 Exp Vibration/Noise??? Stock 2006 -2010 Explorers 10
F 06 4.0 noise. Stock 2006 -2010 Explorers 41
H Minor whining noise from rear? Stock 2006 -2010 Explorers 3
J Air flow noise 07 Mountaineer Stock 2006 -2010 Explorers 5
Dre 06 Mounty, front end noise Stock 2006 -2010 Explorers 2
D Introduction and problem with driveshaft noise Stock 2006 -2010 Explorers 1
F Vibration/Noise at specific RPM Stock 2006 -2010 Explorers 0
K Clicking noise Stock 2006 -2010 Explorers 2
G Rear Air strange noise on 2010 V8 4x4 Stock 2006 -2010 Explorers 2
J 2007 Noise when turning Stock 2006 -2010 Explorers 2
P Front End Noise in 4x4Hi and Lo Stock 2006 -2010 Explorers 4
B Anyone got any loose change? Front End Noise... Stock 2006 -2010 Explorers 10
Mitchs07explorer Intermittent Squealing noise Stock 2006 -2010 Explorers 7
R noise from suv starting at 50km/h Stock 2006 -2010 Explorers 3
L 2007 Ford Explorer idle noise Stock 2006 -2010 Explorers 3
T Rear Differential Noise Stock 2006 -2010 Explorers 3
C Fan Clutch Noise then engine overheats - 4.6L V8 Stock 2006 -2010 Explorers 11
D Diagnosing Noise Help Stock 2006 -2010 Explorers 5
N Whining noise when cold start, 2006 V-6 Stock 2006 -2010 Explorers 3
E Explorer 06 XLT Humming Noise underneath only when 4X4 active after Wheel skid. Stock 2006 -2010 Explorers 20
R 2007 Explorer humming noise Stock 2006 -2010 Explorers 9
E Explorer XLT Humming Noise when 4x4 is fully active after Wheel skidding Stock 2006 -2010 Explorers 0
S Whining Noise Stock 2006 -2010 Explorers 2
G Rear end noise Stock 2006 -2010 Explorers 8
Similar threads
