mkd8919
- June 2, 2014
- Nebraska
- 1993 Explorer XLT 4x4
Hello Everyone,
I have a 92 explorer with 108,000 miles, and I’m having some problems but I’m not sure where to start. I’m not sure if these three problems are related or not, so hopefully someone can point me in the right direction.
1. First, and most prominent, happens everytime I start. When I do a cold start, it seems to idle fine, and I don’t have any problems starting. However, if I then shift in to gear, it will almost always die. Sometimes it runs very poorly for 2-3 seconds, and then seems to run normal. If I “stomp” on the gas 2 or 3 times after it’s started, it won’t die when I shift. I don’t have to rev it up much at all, I basically push the pedal down 2 or 3 times, just long enough that it starts to respond. After starting, I don't have any other problems while driving.
2. When driving at highway speeds ( 60+ mph), The check engine comes on intermittently. There is no change in performance from when the light is on to when it’s off. I would say it’s on at least 45% of the time when driving at highway speed. It never comes on when I drive around town.
3. I just found this the other day. If I floor it, and it downshifts into second, it will rev up to around 4k rpm, which seems to be 60-65mph. It won’t shift up at that point, and just hang there. If I let off the gas until it downshifts, it will then gain speed and get to 75. It does not have this problem in 1st gear.
From my research today, I was able to pull the codes. I got a 539 during KOEO, and then 181, 185, and 186 CM codes. Any ideas? I did notice that the AC was on when I ran the test, if that makes a difference.
