o/d light flashes | Ford Explorer - Ford Ranger Forums - Serious Explorations
o/d light flashes
m4dc0w
Edmonton, AB, Canada
Explorer 97XL
after a recent highway run, we noticed the o/d light flashing. Then the CEL came on.
Since I remembered I had my programer in the truck, I decided to pull the codes, and reset them.
This is what I got:
P0732 Gear 2 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P1000
P1762
After the reset, only the o/d light flashes now.
on highway speeds the rpms are approx 3100.
Any suggestions?
Should I look into fixing it? or putting her out to pasture?
-MC
Check the bulkhead connector on the internal wiring harness.
It's the wiring harness on the transmission for the internal electrical components.
Do a search on tsb 02-13-8. There's a lot of info on this here.
finally had time to look at wiring harness, looks fine.
What next?
Ken
A continuity tester has to used to check each wire from one end to the other on the internal wiring harness.
