O/D Light Flashing? Help!!! | Ford Explorer Forums
Sloth
NJ
'00 XLS
No sure if this is the right spot for this thread, so mods, move it if it is and let me know.
2000 Exploder SE Automatic 6cyl, 74,015 miles.
O/D light is flashing. Checked the manual, it says to have the tranny checked.
I can't say it goes on in conjunction with a specific event, but the trans has been warm the 5 times it's happened over the past 4 days.
If I turn the truck off, it resets it.
It seems when it goes on, the trans wont downshift, or doesnt want to. Trans computer going bad maybe?
I checked my trans fluid, its good, and level is fine.
Trans has been starting to slip a touch over the past month or so. This is new, and I dont want to drive long distances and worry about something going boom, and leaving me stranded with a puddle of gears under the truck.
Anyone?????
your transmission is going into limp mode from what i understand its not good to drive it like that at all...search limp mode
A flashing O/D light means that a transmission trouble code or codes have been stored in the PCM. The codes need to be read to give you a starting point.
when my o/d light started flashing i had to get the tranny rebuilt in the end...hopefully it wont come to that for you...
