O2 Sensor Codes listed
scrollmaster
Northeast Louisiana
97 Explorer XLT 4.0L SOHC
97 Automatic 4.0 SOHC 168,700+ miles. Had exhaust pipes, mufflers and catalytic converters replaced about year ago. They also replaced the 2 O2 sensors that were easy to reach.
I'm Getting 5 DTC errors...
P0135, P0141,P0155, P0161 - All giving Heater Circuit Malfunction with related Bank and Sensor location.
P0156 - Sensor Circuit Malfunction Bank 2 Sensor 2
What are your reccomendations
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
If you are getting Heater Circuit codes for all four O2 sensors, I would look to a fuse first - pretty sure one fuse runs all four heater circuits. Re the P0156 - Bank 2 Sensor 2 is Driver's side behind the cat. Was that sensor replaced last time?? Check that the wiring is OK - it might have gotten misrouted when exhaust work was done.
